Question case for z390 aorus pro with kraken x62
trikolad
6
I bought a case that didn't fit (fractal r5) and now I need to switch.
I was thinking about cm h500p but it can hold only two 3.5 hard drives and I need more.
so fractal r6 might be the best option.
I am also considering x71 thermaltake but it is huge and I don't know if it is has good thermal and airflow
I am also considering antec p110, cougar, nzxt h500, phantex p400s, but I realy don't know which will fit my board+cooler and have enough drives.
p.s.
cpu - 9900k
gpu - 1080ti
I don't quite understand how it's not working, you should be able to get the AIO into that chassis in the front if you remove the HDD cage. Perhaps if you can elaborate on what's impeding your installation of he AIO+the board? Logically you can return the case and pick up the successor to the R5, the R6 or the Meshify S2.
Best list your fulls pecs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
and also what your budget and preferred site for purchase is?
I want the cage, I will use quite a few hard drives.
my budget ends at R6 price range. basically I need it to fit the aorus pro z390 with kraken x62, and to have place for at least 3 3.5 hard drives and some ssd's. that's why unfotunately I cant take h500p coolermaster.
thermal's are most important to me but noise too as much as possible.
CPU: 9900k
Motherboard: aorus pro z390
Ram: 2X16 hyperx fury 3200rpm cl18
SSD/HDD: 3X mechanical hard drives, 2X ssd's, 2X m.2
GPU: evga 1080ti ftw3
PSU: seasonic focus platinum 850W
