I recently completed a HTPC build with a ITX case I had lying around. The case's front panel connection is standard pin but of the type where all the wires are attached into one single connector.
In this build I installed an internal IR receiver that connects through the front power switch connector so that you can turn the computer on/off with the remote and no wake on usb needed.
I got it working with that connector, but since I can't split the wires, I was not able to wire up the power light and HD light wires.
I'm trying to find some kind of splitter that will let me split that connector into its individual wires so I can have the power switch wires go to the IR receiver and the others straight to the motherboard.
Was surprised I couldn't easily find anything online. Does anyone know where to get something like this or how I can get around it some other way?
Thanks - H
Thanks - H
