Question Case/gcard/350mm aio fitting.
Flow483
99
Hi everyone,
I recently purchased the AP201 case for my new build, but I'm a bit concerned about fitting my graphics card with a 350mm AIO cooler. I know this case allows you to reposition the power supply to three different locations: top, middle, and bottom. I was wondering if anyone here has experience with fitting a 6900 GRE GPU in this case while using a top-mounted 350mm AIO cooler.
Alternatively, I’m considering either switching to a 6800 XT or keeping the 6900 GRE and opting for a 250mm AIO, with the power supply mounted in the top position. Ideally, I’d prefer to use the 6900 GRE with the 350mm AIO, so I’m curious if anyone has encountered this specific situation or has a definitive answer on whether it will fit.
Thanks in advance for any insights!
no experience of that case (I'm guessing here so take it with a pinch of salt), but I just looked it up and it looks like there is room for your GPU, and the top has three fan places so it should be big enough for the AIO
if you already have the case you should just be able to measure it, and measure/look up dimensions for AIO and GPU and check it will fit
yeah i already have the case. That's a good point, ill just measure it will the power supply in its middle position and look up graphics card dimensions when i get home.
Reactions: RAIDGoblin
