Case help please
It should be okay, according to the website. It depends on use. What are you planning on putting in there?
i5 4670k, gtx 770, 8gb of ram. And I'll probably OC the CPU and GPU
I'd go for a different case with those parts. The reason that particular zalman case doesn't have a front fan is that it's supposed to be quiet: the psu fan is cooling motherboard components by creating positive pressure in the case but allowing cool air from the bottom of the case to enter.
You do not want your PSU alone to cool that system.
