Question Case Help
Nov 9, 2020
13
what the best Budget Case with good airflow to fit in my B450 AORUS ELITE mobo with ryzen 5 3600 and gtx 1660 super !!!?
Prad_Bitt
Notable
Jul 4, 2020
1,082
244
1,140
39
Does it have to be the mesh one ? cause i think the default one is the only one available
Mesh is better for airflow. More valuable than anyone would think. I have a 275R non airflow. So it has a blocked off front with 1/4" gap on the sides to pull in air. I do not have the front panel on, I took it off, stored it away. Now I can see my rgb fans, and have lower Temps, albeit with more noise from fans
