Case Help.
Nickos
30
G'day,
Here's my Delmar;
i originally wanted to buy a Xaser VI LCS
(See someone does read the Stickies before posting)
But then while shopping for a HD4770 i came across this Site Which is stocking a CoolerMaster storm sniper AMD Special Edition Which cause i am a Crazy AMD fan, pretty much made me scream. Now i really want this case But my problem is that will all my parts fit even if it is a tight fit?
Proposed Specs; (feel free to recommend anything else)
Motherboard;
GA-MA790XT-UD4P
Processor;
AMD Phenom II X4 955
Memory (ram);
CORSAIR TW3X4G1333C9 8GB (4x XMS3 2GB) PC-10600
Storage;
SAMSUNG 1PK 1TB SATAII 3.5 32M
PSU;
CORSAIR 620W Corsair HX-620 ATX Modular Power Supply,
Okay here's were the problem begins;
Watercooling;
Thermaltake. Dual 5.25 Drive Bay liquid cooling system (CPU water block and 2x GPU water blocks)
Optical; (2x)
LG 22xDVD+-R, 12xDVD-RAM
AND
Graphics card:
Crossfire HD4770
+wIfi card/cold cathodes
So will this fit or will it just be too much for the case to handle?
I have to agree with swifty_morgan, if you're going to go through the trouble of water cooling you might as well get a good pair of GPU's to Xfire. Try the 4870 1GB
but if you still want to go through with that, from the dimensions i looked at it should fit
Thanks Tidefan94,
@ Swifty_morgan
Thanks for the sugestion but next time would you be kind enough to suggest another model or make? 😀
@thefox14
Thank you, i thought of the 4870 512mb at one point, but i think that would great having 2 4870 1GB's in X-fire.
thanks, yeah it was just a sudden thought that it might not fit.
