G
Guest
Guest
Let me give you the situation first. A friend of mine was asked to build a desk for some local exec. He built a desk and made it so the desk could be smooth and uncluttered. The flat panel monitor comes up from the desk when you touch a button, similar to the way a cd tray comes out. The keyboard and mouse is on a retractable tray. The cd drive and floppy drive are built vertically into the desktop, so you hit the eject button and the tray comes out of the top of the desk. It's really a cool setup.
He asked me to design the case, I know he is going to need goo airflow as the case is bult into the desk in a confined space. I was looking to mount an intake at the bottom and an exhaust at the top (both the PSU and a small fan under the PSU on the back). The intake is posing a problem. All the fans have to be on the back of the case, the top, front and sides are against parts of the desk. I was going to use one of those slot exhaust things and switch the fan to blow in, it did a horrible job and really didn't blow enough air in.
I was wanting to have air coming in blow directly on the video card, but as I type this I really don't think that's necissary even if it will be used for gaming. So I am thinking a fan blowing into the case from a few un-bracketed slots would be fine (the open spaces from the slots blocked off). I think that's what I'll probobly do, what do you think?
