How do you split the fan cable to the led cable and fan cable respectively?
Yes. The problem is that my case cm storm scout 2 offers an led switch feature and I do not know how to connect an extra led to it. The manual stated that a led cable should be plugged to the switch. But I can't find it on the case fan. is there a particular cable I need to work on? Or is there a fan with that cable? Am @ able to get them at a normal, local computer store? I intend to buy a fan controller. And my motherboard is asrock h97m anniversary just in case you want to know.
