[Case Mods]Seeking advice for custom radiator mount on Lian-Li PC-Q08
sluggercz
48
Hey dudes,
I am currently modifying my Lian-Li PC-Q08 to fit a 120mm radiator with push/pull Noctua NF-F12 PWM fans, but find myself in a conundrum...
The stock setup has a 140mm fan attached to a quick disconnect bracket with removable fan filter. The disconnect bracket attaches to another bracket which itself is attached to the inside of the front of the case. I need to create some sort of bracket with which I can mount the front of the radiator setup(which is a 120mm-to-140mm fan adapter) directly to front bracket.
(Hard to picture, so here's some pictures :lol: )
//BRACKET + 140mm Fan
//My Radiator Setup
//My Proposed Bracket (lulworthy blueprints)
If you cannot tell from the images provided, my plan is to create preferably a bracket from a piece of black anodized aluminium, or less preferably some black plastic material - probably acrylic.
//The question!
How would I go about cutting aluminium sheeting in a manner that would give me nice clean lines? Or, is that a pipe dream and should I pursue a simpler material such as a plastique?
Any and all advice, comments, and suggestions are welcome! And thank you for reading the post, cheers. :sol:
So I tried to make the bracket myself with a jigsaw and some .25in aluminum sheeting but was unable to cut a center hole that had clean lines. (Used a jig-saw around the perimeter of the rectangle, drill bit w/ circular router for center hole which couldn't penetrate the sheeting and gave off a ear-raping banshee shriek at the same time)
Are there any online contractors where I could send a 3D model made up in AutoCAD or some other program?
Thanks.
