Question Case only has 1 front panel cable? (powersw cable)
Apr 6, 2019
17
title says it all, mildly confused since I've seen most people have quite a few more than I do, I'm a bit of a noob so for now my only theory is that the other cables are preassembled in the back side where the hubs are (using noctis 450 rog)
The Noctis 450 ROG is a match-up of an ageing NZXT enclosure and the Asus Republic of Gamers brand. Re-styled to incorporate grey paintwork and RGB illumination, the chassis' defining feature is out-the-box integration with Asus's Aura lighting ecosystem.
Each RGB lighting zone is bright and easily configurable.
The RGB lighting changes didn't do enough to bring the Noctis 450 up to date in 2017, and the RGB illumination claimed a heavy price leap over the standard model that was available in 2017 for less. It has since been discontinued.
You need an ASUS motherboard to sync with the case to enable you enjoy its RGB features.
Front panel ports
Front Ports: 2 x USB 3.0 / 2 x USB 2.0 / 1 x Audio & Mic
I/O Panel and Lighting System LED On / Off
