Case + Power Supply
tryceo
52
I wanted to build a gaming comp with some nice overclocking going on.. I'm trying to find a good Case and Power supply that will support i7 920 OCed to 3.8ghz and GTX 275 SLI (and maybe tri sli in the future).
Case: I want a roomy case with nice air flow.. Good looks would be a plus
a. Antec 1200
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043&Tpk=antec%20twelve
b. HAF 232
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
c. COSMOS 1000: Im not really sure about the air flow in this one... doesn't seem to have a lot openings.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119138
Power Supply: I want it to support GTX 275 SLI and maybe SLI GTX295 x 2 in the future.
a. Rosewill RX 850
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182070
b. Antec 850W (made for 1200?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371024
c. Corsair 850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009
b. Zalman 850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817379007
d. Antec Quattro 1000W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371012
e.Kingwin 1000W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121037
d. SilverStone 1200W(too much power?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256041
If you have any other good cases/ PSUs plz post.... this is like last part of my built that i cant decide on
tryceo
52
No.. Im not buying 4 295s...
I buying two of them and SLI them.. so thats basicly = 4x GTX 275
