[SOLVED] Case Power Switch Not Working
Apr 7, 2020
8
Hello Everyone
B450 Tomahawk
NZXT H510
I am nearing finishing my first build but was having trouble getting my case power switch to actually work. I've connected the cable multiple different ways to no avail. The pins definitely work as I just jumpstarted the build without any problems. What's also puzzling is that the power button on the case lights up but doesn't work. I have attached a few pics for you to tell me what you think.
View: https://imgur.com/5i6prck
View: https://imgur.com/PHWIEEM
View: https://imgur.com/a/3PuP7HQ
if that isn't working properly, then issue might be with the power button itself, or the pcb the those tiny cables connect to that is glued up into the front panel of your case
Welp I just found the soultion. The cables we wrongly labeled the hdd light is actually the power switch. Never expected this to happen for my first build. Thank you for your help greatly appreciated.
