[SOLVED] Case recommendations for these parts?
Jan 10, 2021
Hi! First timer in the world of PC building. So I have purchased parts and checked any compatibility issues using PCPartPicker.
Parts:
CPU:
AMD Ryzen 5 3600
Cooler: Scythe Mugen 5 PCGH Edition
Motherboard: MSI MAG X570 Tomahawk Wifi ATX AM4
Memory: Kingston HyperX Fury 16GB (2 x 8 GB) DDR4-3200 CL16
Storage: Kingston A2000 250GB M.2-2280 NVME (for OS) + Samsung 970 Evo Plus 1TB M.2-2280 NVME (for games and photoediting apps)
GPU: MSI Geforce GTX 1660 Super 6GB Ventus XS OC
Power supply: Seasonic Focus GX-550 80+ Gold Certified Fully Modular ATX
Case: SilentiumPC Armis AR1 (which needs to be changed)
Later on I found out the case is not compatible with the motherboard. There is a non-removable HDD bay blocking some of the connections to the motherboard. So obviously I need a new case.
Question is what you recommend as a case for this build? I'm a first timer and I need a simple case with space to work on.
Thank you in advance!
Prad_Bitt
Notable
Jul 4, 2020
1,098
245
1,140
212
What's your budget? The Corsair 4000D airflow is a great choice imo for a simple case. No rgb fans no extra controller, removable hard drive cage. Phanteks P400A is also good.
Prad_Bitt
Notable
Jul 4, 2020
1,098
245
1,140
212
