@bryan0629 Any ATX or micro ATX case will do, here's some I looked up, the first two are micro-ATX only and the others are ATX, the ATX ones will be larger but can take a full ATX (larger) motherboard so you would have more choice if you ever upgrade in the future. And not forgetting what I learned from my sleeper build in a old cramped case, bigger cases make for a much easier time - some will probably argue better airflow too
another thing to consider: you're motherboard doesn't have an RGB header so you'd need some form of RGB controller to run the front fans
micro ATX:
Cooler master MasterBox MB320L ARGB:
https://www.pc-canada.com/item/MCB-B320L-KGNN-S02.html (this one doesn't include an RGB controller, it's beyond my knowledge to say what you would need to make cooler master ARGB work with your system but I'm sure it can be done relatively easily)
Fractal design Focus G mini:
https://www.pc-canada.com/item/FD-CA-FOCUS-MINI-BK-W.html (front fans aren't RGB, they're just white LED - but you won't need an RGB controller, unless you changed the fans for RGB ones, this case also takes DVD drives)
ATX:
(none of the following are in-stock but I'm sure you could find them somewhere else without much difficulty)
Thermaltake H330:
https://www.pc-canada.com/item/CA-1R8-00M1WN-00.html (only comes with the front fan and doesn't actually say what RGB compatibility that has)
Fractal design Focus G: comes in blue and red as well as black:
https://www.pc-canada.com/item/FD-CA-FOCUS-BK-W.html (front fans aren't RGB, they're just white LED - but you won't need an RGB controller, unless you changed the fans for RGB ones, this case also takes DVD drives)
these last two are a bit on the pricey side but they come with an ARGB controller that I think is capable of driving the fans and LED strips without RGB on the motherboard (as I'm not an expert with RGB I would ask someone else here before choosing, to be sure), also I think they are cool:
MasterBox Lite 5 ARGB:
https://www.pc-canada.com/item/MCW-L5S3-KGNN-05.html (airflow is probably poor because it doesn't have a fan space on the top and the front isn't mesh)
MasterBox MB500 ARGB Case:
https://www.pc-canada.com/item/MCB-B500D-KGNN-S01.html
