Baily Case :
Gam3r01 :
Yeah they are all molex. If you look closely you can see on each set of fans there are 2 molex plugs, one male, one female. You plug the power into the female end, and then if you need to plug in more fans they then plug into the male portion of the fan.
So how many molex plugins would i need to supply all the fans in the case?
I was running all 3 fans off of one connector from the PSU.
Pretty much, chain them together and see where it gets you, some may be too far apart. You should be able to use 2 for all the fans. One for the front and sides, one for the rear fan.
This depends on how long the cables are, if you can get them all chained together it will work off 1.
