Thinking about a case upgrade, and have it narrowed down to these three.
Rosewill THOR 2
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
Thermaltake Level 10 GT Snow Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133192
Rosewill BLACKHAWK ULTRA
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147157
Here is what will be going in it; I'm going for maximum airflow while keeping plenty of room for my bulky Antec Kuhler H2O and the fans alongside it, as well as what will eventually be a GTX 980 SLI. Better cable management will also be a plus.
CPU: Intel Core i7 4790k
CPU Cooler: Antec Kuhler H2O 950
GPU: EVGA GTX 980 SC
PSU: EVGA SuperNOVA 750W
RAM: 16GB DDR3 Patriot Extreme 2400mhz
Which would be my best choice? Or do you have another you'd recommend?
Thanks!
Rosewill THOR 2
Thanks!
