There is a small, rectangular black piece of plastic at the end of my Corsair Spec Delta’s USB 3.0 connector that won’t fit the motherboard header, but it looks like if I remove it it’ll fit. Is this a good idea?
Motherboard header (Gigabyte B660 Gaming X AX rev 1.0 ) https://imageshack.com/i/pn9TTng1jAdd an image of the ports/connectors you're having an issue with and include the make and model of the motherboard.
Yeah, it was actually, from the same model just without WiFi 6. So it’d be safe to pry off then?Was the case used with another build/motherboard prior? That USB 3 for the case looks like you ripped the boot out of your older motherboard.
