Case Vibrating plz Help
Kiesow_21
Commendable
Apr 3, 2016
My case is vibrating but when i apply presure to the top of the case it stops. like i even have to set an object on the top of my case just to have it quite. please help.
You need to investigate what is causing the vibration, fans or hard drives. You can get rubber "screws" for mounting fans along with anti-vibration mounts or better fans with these things already included. Hard drives are not as easy, but you can try to isolate them, suspend them, or replace them with SSD's.
