Case wire connections Need help quick
DeumBelli
116
I have a few wires left to plug in and im not sure where they go. I have nzxt h440, z97 gaming 5 motherboard, and 750 evga supernova g2. I dont know where to plug in the hd audio cable from the case and how to hook up the 4 case fans. Can someone help me as soon as you can?
If you want to use the on-board fan controller, yes, I think so. You will need to plug the Molex connector from your fan controller into a Molex connector on one of your power supply cables.
you could unplug your fans from the controller and plug each one into the motherboard using one of the fan headers.
I found wht to do with the audio connector but for the fans all i see is a molex plug ( i think thats what its called)
i have the cpu fan plugged into the cpu fan on the motherboard but idk what to do with the 4 case fans all i see is a molex plug and one small 3 pin cable. Can i just plug the molex into my psu and the fans would work?
I still have the problem of only seeing the molex cable for the fans. Am i supposed to use that since in the case manual it says the molex is connected to the fan hub? Because i dont see anything else to plug in.
