I don't remember having this many issues figuring out where the case wires go. I think Cooler Master was easier. This is my first Corsair case- 760T. Looking in the manual for the Asrock x370 Tachi, I saw HDD LED, power switch, reset switch, led +, led -...Is anyone familiar with this MB? For the case wires, I see they aren't labeled positive/negative or with any triangle. DOes anyone know the correct way to connect (the HDD LED wire has the lettering face down etc) or would this be a simple fix, I press the power button, system doesn't turn on....unplug everything and flip wire?
Also, with only 2 USB headers, seems like I quickly found I have no more USB headers If I'm using COrsair link? I have the 115i plugged in and the commander pro for the case fans. These 2 used up my 2 USB headers. Seems like I can't plug in the case USB wire or the corsair link wire from the PSU. I guess if I needed more USB sockets, I should of gotten a motherboard that provides more?
