mrclownface
633
5
19,065
my new pc has a coolermaster storm enforcer case,it has a usb 3.0 at the top front panel,it was$100AUD ,it depends what type of case you like
adam1712
86
+1 to this, i built my first computer about 2 weeks ago with this case and it is brilliant, it has 2 usb3 ports at the front, i think it was £70. It has loads of space you can take out one of the HDD cages for extra space fits my huge GPU and cooler in no problems. I would recommend getting the red led coolermaster 200mm fan for the top too, it is exactly the same as the pre built front fan and makes it look awesome! :)
jockey
746
Does your mobo have a USB 3.0 header on it?
I ask this because some cases route 3.0 cables out the back of the case to connect to the rear panel. Others have a 3.0 header which connects directly to the mobo internally.
