R Relaxation 2 Prominent Aug 4, 2017 4 0 510 Aug 4, 2017 #1 My Korean case has an USB 3.0 but my motherboard doesn't. What do I do?
Solution CountMike Aug 5, 2017 Get an adapter like this http://www.ncix.com/detail/usb-3-0-19pin-to-usb-d7-98864.htm small part fits on MB and other side to your USB3 cable from the case. It will still work only at USB2 speeds. Another option would be a PCI/PCIe card with internal USB3 ports(s). http://www.ebay.com/itm/PCI-2-Ports-Express-USB-3-0-Front-Panel-with-4-Pin-20-Pin-Control-Card-Adapter-/292105911317?epid=839814722&hash=item4402de7c15:g:G3IAAOSw~y9ZCtjs
CountMike Titan Oct 31, 2015 35,726 3,867 147,990 Aug 5, 2017 Solution #2 Get an adapter like this http://www.ncix.com/detail/usb-3-0-19pin-to-usb-d7-98864.htm small part fits on MB and other side to your USB3 cable from the case. It will still work only at USB2 speeds. Another option would be a PCI/PCIe card with internal USB3 ports(s). http://www.ebay.com/itm/PCI-2-Ports-Express-USB-3-0-Front-Panel-with-4-Pin-20-Pin-Control-Card-Adapter-/292105911317?epid=839814722&hash=item4402de7c15:g:G3IAAOSw~y9ZCtjs Upvote 0 Downvote Solution
