12600k no oc + RTX 2060No it won't.
What components are you planning on installing in that case?
it will be 12600k no OC with RTX 2060 and 32GB RAM, do your recommend such as components to be inside solid front case ?What parts will be installed inside?
Such cases will have vents on the side or bottom to admit air to the front intake fans.
Unless you have very hot components inside, I would not dismiss the case out of hand.
I would not use a top intake fan. It will just keep heat inside of the case.
I would not use a top fan as exhaust either. It would tend to divert the front intake cooling airstream up and out of the case without doing any good.
If the front intake airflow is not sufficient, you can replace the front intake fans with higher RPM versions at the cost of more noise.
actually this case is only 50$ this is why i want to buy it as it cheap and look nice but as you said its very bad for hot temp roomsI'm not sure how I'd feel after spending $150 and getting an acrylic side panel.
In any case, what is the ambient temperature of the room? We occasionally have people in hit climates who don't have a/c running PCs in a room that starts out at 35 and hotter in the summer, and that takes away some of the margin of a restrictive case. I'd personally never build in a case like this, but I prioritize my parts running cool.
No. Pass.it will be 12600k no OC with RTX 2060 and 32GB RAM, do your recommend such as components to be inside solid front case ?
