Cat6a wired ethernet throughout my home
ali.avey50
I just installed a wired Cat6a network n my home. Do I connect my ISP to the router/modem with Cat6. And, do I need to use Cat6a compatible switches?
Do I need to upgrade my modem/router?
So lets do a quick break down of cable speeds
Cat5e = 1gbps
Cat6 = 10gbps to about 50ft, 1gbps beyond that
Cat6a = 10gbps up to the full length (which is 300ft)
There is no such thing as cat6a switch, there is only 1gbps switches and 10gbps switches (and a few other speeds).
If you want a 10gbps network then all of your switches and computer network adapters need to be 10gbps rated (this is still quite expensive).
Your patch cables should be cat6a, and in-wall cables and walljacks need to be cat6a
For 1gbps you can connect anything from cat5e to cat7 cables together and it will work just fine.
Typically the desired setup for a wired home is modem connected to router (if modem and router is sperate), the router connected to switch, and...
You don't HAVE to upgrade anything. If you have more wired connections than your router supports then you could buy a gigabit switch and run all your wired connections to the switch. You then run a single cable from the switch to the router. If your patch cables are cat5e or better then you are OK. If your patch cables are old, the wrong length, or questionable. Buy new ones. They are cheap and help eliminate problems.
Cat5e = 1gbps
Typically the desired setup for a wired home is modem connected to router (if modem and router is sperate), the router connected to switch, and all the cables going to your rooms going to the switch (switch being located in the panel/box/rack that all the wiring goes to).
