I just installed my new HD7770 ( http://www.amazon.co.uk/Sapphire-11201-17-20G-CrossFireX-Multi-GPU-Technology/dp/B009YTT5RW/ref=sr_1_1?s=computers&ie=UTF8&qid=1388403112&sr=1-1&keywords=Sapphire+11201-17-20G+AMD+Radeon+HD+7770+1GB+GDDR5+GHZ+Graphics+Card+%28HDMI%2C+DVI-I%2CPCI+Express+3.0%2C+128-Bit%2C+AMD+CrossFireX+Multi-GPU+Technology%29 ) and I'm getting this error when I try to open CCC
"The application ha failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxtrace.exe tool for more detail"
How can I solve this issue so I can go into Catalyst Control Centre?
Also, I'm using dual monitors (one HDMI, one DVI.) They were working until for some reason, my system restarted and the monitors can't be detected properly. It says "Default Monitor (on)" instead of detecting two different monitors. It clones the image on both monitors, can anybody explain this?
Thanks.
Thanks.
