CD Drive problem in old computer
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.compaq (More info?)
My son is the proud (?) owner of a Desktop EP5000 that i gave
him for his first forage into computing.
While i used it i had no need to insert any new hardware, so never had the
need to lift the cover.
However, on trying to fit a CD burner to it i hit a problem
Its the model that you can have, either as a tower, or a desktop, but, on
trying remove the CD drive
i couldnt, as its a strange setup in there.
There is, not the "normal" layout, but a "cage" holding all the drives -
floppy, HD and CD drives.
On the top of said cage there is a green plastic strip and a yellow button
that i assume is to
release all the drives, but, try as i might i cant get anywhere when trying
to release the drives.
Is there a "knack" to this, or is there a fault with it?
Any, and all help appreciated
Purdy
I wish you enough sun to keep your attitude bright.
I wish you enough rain to appreciate the sun more.
I wish you enough happiness to keep your spirit alive.
I wish you enough pain so that the smallest joys in life appear much bigger.
I wish you enough gain to satisfy your wanting.
I wish you enough loss to appreciate all that you possess.
I wish you enough helloes to get you through the final good-bye.
hh
645
The drive releases are individual for each drive. The green strips on the
sides of the drive cage.
HH
"purdy" <purdynospam@nospamegremont.plus.com> wrote in message
news:424a60c7$0$26481$ed2e19e4@ptn-nntp-reader04.plus.net...
> that i assume is to
> trying to release the drives.
> Purdy
> bigger.
