are you sure you connected it? Is it detected in the bios?
Is the cable on correctly?
Open the tray and see if you can see that the lens is still there?
I've seen them fall off on some drives.
Edit - And if your is one that has a "Play" button on the front, pop in a music cd and see if it will play that.
