G
Guest
Guest
Recently got an aging CeleronA 300Mhz and a "P2XBL revB" of which I know nothing apart from the printings on the board.
These components being terribly ancient (but cheap), I want to push it them as far as I can go without replacing the cooler on the CPU (I think that'd be hard to do). Currently I've got it running stable at 374Mhz, but is unable to take it to 450Mhz without seriously sacrificing system stability.
Hardware monitor reads CPU temperature: 30C at bootup to 41C at most. Core voltage: 1.54v. These readings appear to remain constant wether running at 374 or 450Mhz, indicating to me the instability may be cause of insufficient voltage?
In that case, I've read that, there being no way of manual adjusting voltage, I have to tape over some pins on the CPU. Which ones would be dependent on the voltage desired.
So I ask you (whichever knowledgeable person(s) that may read this): What's a good CPU temp for a Celeron?
Which voltage setting would you recommend? Is nailpolish gonna do the job? Anything I ought to know?
Yours
Niels Peter
Yours
Niels Peter
