[SOLVED] Central hub for audio and visual connections?
jamieblow1234
Commendable
Aug 9, 2018
4
Hey!
I'm attempting to set up a projector system in my bedroom, where i also have my pc and my consoles. Is there some kind of central hub system I can purchase that will allow me to connect everything to it, and i can then choose which output it will be? (Monitors/TV/Projector)?
Would save me an age trying to change over the ports everytime I want to change to the console to play games or stream netflix, but I would also love to be able to duplicate my PC monitor display onto it.
Thanks,
Jamie.
Yes, lots of HDMI hubs out there with a switch to select the input you want, some even have a remote. You'll want to find one that works for your needs, 4k or 1080P 60Hz or 120Hz. Can't tell you what to get but they are available.
The trouble I'm having is, I want one with multiple outputs, to speakers etc. My friend had something similar where it had a dial on the front that selected inout/output/speaker volume etc.
Any idea what I could search to find something like this?
