I upgraded to an i7 4790k a few months back and ever since, under specific circumstances, certain in-game sound effects will trigger a massive drop in frames, almost as if the rendering briefly stopped when the sound effect was actuated. The the game will render normally throughout the duration of the sound effect and it's only the exact moment the sound effect starts that effects performance.
The two most repeatable instances I've found are when playing Mario Kart Wii with the Dolphin emulator and in Team Fortress 2. In Mario Kart Wii, the triggering sound effect is the tune that plays to signify when the third-lap has started. In Team Fortress 2, the chime that plays to once a reusable item (such as Jarate or Mad Milk) is refilled triggers the issue.
This problem occurs whether or not I'm overclocking or running on stock settings and I've updated all drivers and motherboard bios to see if this helps to no avail. I also uninstalled the Sound Blaster software that came with my motherboard thinking that possible the Scout Mode was causing the issue but that didn't work either.
I'm starting to think that this is a Hardware issue because I never once had this issue when I was using an AMD Phenom II x6 1100t. I'm still using the same GPU on my current z97 system as I was in my previous AMD system so the only two variables left are the motherboard and the CPU
So I'm not really sure where to go from here to troubleshoot it further. Anyone else have experiences with an issue like this?
