Certain parts of python scipt not being executed
Biglemon29
113
Under the choose option 2 part. If the input is bread the rest of that part won't run. The script just ends there. What is wrong can someone tell me? I don't get any error message the script just stops. Other than that everything works
bread = 44
lettuce = 21
meat = 21
cheese = 23
sandwich = bread, lettuce.meat, cheese
choseOption = input('What you like to mark an order, add to stock, or check stock')
if choseOption == 1:
newOrder = input('what did they order?')
if newOrder == 'sandwich':
bread = bread - 4
lettuce = lettuce - 5
meat = meat - 7
cheese = cheese - 10
print(bread)
print(lettuce)
print(meat)
print(cheese
if choseOption == 2:
newStock = input('What would you like to add to stock?')
if choseOption == 'bread':
addBread = input('How much bread would you like to add? ')
bread = bread + addBread
if newStock == 'lettuce':
addLetuce = input('How much lettuce would you like to add?')
lettuce = lettuce + addLetuce
if newStock == 'meat':
addMeat = input('how much meat would you like to add?')
meat = meat + addMeat
if newStock == 'cheese':
addCheese = input('how much cheese would you like to add?')
cheese = cheese + addCheese
It's painfully simple. You are assigning "newStock" the input value but are checking "choseOption" to make your decision. All of the other blocks correctly check against "newStock".
Biglemon29
113
I don't understand what you are saying. can you post the updated code? maybe then I will understand. Thx for the help though
Biglemon29
113
never mind I got it. Sometimes I just make silly mistakes like that and I can't find them. thx for the help
Can't be any simpler
newStock = input('What would you like to add to stock?') <-- You assign a value to "new Stock" here
if choseOption == 'bread': <-- You check here. Note that you are not checking against the input value you assigned above.
