I purchased one of these
http://www.hollandcomputers.com/productcart/pc/viewPrd.asp?idproduct=6337&gclid=CJ2r6LHDkLQCFSWoPAodYxcAXA
I used the included wiring harness and soldered all of the relevant connections from my jamma harness and checked it thrice.
There is only 1 sync wire coming from my harness so I twisted the two together as normal on the converter harness.
I am currently using the +5v power from my arcade power supply to power the converter.
In the PC monitor I can see the logo and on screen menu properly but cannot see the screen. After changing settings I will occasionally get something to come on the screen but it will be mostly green or a grid of small screens.
I've tried all manner of messing about with the sync.
I've replaced the CPS2A and B boards, I've tried MVS,
I noticed in the instructions that it mentions needing a 2amp 5volt for the power supply. I am using the 20amp 5volt off of the power supply.
Does anyone have any experience with these or perhaps know what could be causing the video not to work? I have seen many successful setups with the exact hardware on Youtube. I do not know why I am having such a problem.
Many thanks.
Many thanks.
