G
Guest
Guest
HI,
I 've just built a new system , with an asus a7v266-e and amd athlon xp 2000+
Everything was fine , and the bios was showing me "AMD ATHLON (XP) 2000+
the only thing that concerned me it was that the cpu temperature was between 45 and 50 degrees C
so i decided to reinstall my fan/heatsink(swiftech) to check if the overheating was because of a bad installation.
So i take the cpu and i clean it from the artic silver (thermal compound) i use acetone on the cpu core and palmolive soap on the ceramic. I mostly removed all the compound , and all the l1,l2 l3 l4 bridges , seemed quite clean and free.
i reinstall the cpu and the heatsink and the drives and videocard. i start the machine but when i'm in the bios it only allows me to choose (the cpu frequency) between 1010Mz and 1466, and even if i choose 133.33 X 25.5 manually
the bios now it sees my 2000+ as a 1700+ ! ! ! (always core V 1.80)
What should i do ? (i tried to update the bios but no change.)and the system seems not stable as before.
sometimes when i turn it on it shows me Amd Athlon Xp 1900+
but then after a while that it's off and i turn it on , again it says AMd xp 1700+
What should i do ?
did i , in some way break the cpu ? or shorted one of the bridges with the compound ? so the multiplier it's not stable ?
how could i fix it ?
Help!
What should i do ?
Help!
