Change Power supply
Umm, this is a little vague, but I’m going to assume you mean how to physically swap out a psu of a desktop? If not, disregard this message...
1) Unplug everything attached to a storage drive, the mobo, possibly the gpu if it needs a power cable, etc.
2)Undo any cable managing (zip ties for example.)
3) Feed them back out into the main case (you would feed the cables from a device to this smaller area in one of your side panels, and then you feed that back into the main case..)
4) All if your cables should be unplugged and back into the main portion of the case. Just pull it out.
5) do everything in reverse for the new one.
