Change Startup and Shutdown sound
Zuriel Ramirez
Commendable
Jul 2, 2016
88
Hi, as the title says, I wanted to change the startup and shutdown sound in Windows 10, but I have trouble doing it. First of all, I already downloaded the files, which is the sound from Windows Vista BETA and converted the files to .wav to make sure, but as soon as I tested it, it still plays the default starup sound, but gets interrupted like it only plays half of the startup sound. I need help with this since I really want to change the startup sound of my PC!
Renamed the files with the same name of the default system startup sounds, and moved to Windows>Media folder.. I also fixed the settings in the Sounds icon, but nothing happened..
Also, I want the Windows Longhorn to be the startup and shutdown sound instead! It sounds better than the Windows 7 sounds in my opinion!
Figured it out! Apparently you have to replace the file that is located in the imageres.dll, but my computer started having problems so I decided to run sfc in command prompt to fix the issues... For now, I decided not to change it since it won't let me replace the dll file..
