Hi,
So today I was fixing my windows 10 as it had a problem with startup (bad system config info error) and i was starting to install new windows on my SSD. I had the old windows on my HDD and tried to install through a USB-stick.
I changed the boot order in BIOS to USB->SSD and left the hdd away from the boot order. Then the machine restarted with normal beep but monitor or keyboard got no signal.
First I tried troubleshooting the monitor and after testing other monitor and different cables on my laptop it seems the monitor is fine. next i removed the USB and hard drives and reset the bios and got the MOBO battery out for a while for a reset. Nothing happened. Next I went for RAM and GFX but nothing happened.
The startup seems fine there are light on on the MOBO but no external devices seem to work. My mouse does flicker light below it when I click so that's weird. Any ideas?
Specs:
MOTHERBOARD : ASUS P8H67-M
GFX : NVIDIA GTX 560
RAM : HYPERX 4gb 1333 X 2
HARD DRIVES:
KINGSTON 120 GB
SSD WD 1TB HDD
PSU : COOLER MASTER 750W
MONITORS: BENQ 24'' and LG 23''
Specs:
HARD DRIVES:
KINGSTON 120 GB
SSD WD 1TB HDD
