J Jh4nTy Honorable Mar 30, 2016 155 0 10,680 Feb 3, 2017 #1 My question is basically the title. I'm thinking of changing cases so that means moving all the hardware from one to another so do I need to format my PC in order to do that or will I keep all my stuff after the change? Thanks!
Solution P P Paul NZ Feb 3, 2017 No it's only if you change mobo and cpu that you should format the hdd
P Paul NZ Polypheme Sep 15, 2014 20,774 3 61,010 Feb 3, 2017 Solution #2 No it's only if you change mobo and cpu that you should format the hdd Upvote 1 Downvote Solution
Computers Taste Like Metal Reputable Oct 7, 2015 635 1 5,160 Feb 3, 2017 #3 You won't run into any software issues if you're just swapping cases. It should boot back up like it did before the new case. All files in place. Upvote 0 Downvote
Thines_1 Reputable Aug 15, 2016 38 0 4,540 Feb 25, 2017 #4 No.Just move the hardwares to the new case and you're good to go.Just make sure everything is in place. Upvote 0 Downvote
