Changing Drive Letter Assignments
G
Guest
Guest
Archived from groups: microsoft.public.win98.gen_discussion (More info?)
This has probably been asked a 1000 times...
My old AT PC had a single HDD(C:), a floppy(A:) and a CD-ROM(D:).
I've just added a 2nd HDD and now the drive letters are:-
1st HDD (C:)
2nd HDD (D:)
Floppy (A:)
CD-ROM (E:)
I've just changed the device settings for the CD-ROM to be drive (O:)
for Optical.
I would like to change drive letter assignments for the 2nd HDD to
something like "S:" for Spare, but the device manager letter
assignment box is greyed out so I can't change it. Ditto the "reserved
drive letter" fields.
Is is even possible under Win98? If so, how?
Win98 original, not SE, not ME.
G
Guest
Guest
"Gary D." <ignore@notvalid.net> wrote in message
news:bvnrf1hpclti01qaq90qdicg8f8prcs0d4@4ax.com...
> for Optical.
The likeliest cause is that Drive D: is Primary DOS, therefore
automatically assigned the next available drive letter.
You can use FDISK to wipe D: (wiping all data) then create
a new partition as Extended DOS and FORMAT it; then
give it drive letter S:
Don Phillipson
Carlsbad Springs
(Ottawa, Canada)
G
Guest
Guest
In that the letters are assigned by the system, how would a user assign a
letter other than by using a third party program such as Letter Assigner?
Regards
Ron Badour, MS MVP for W98
Tips: http://home.satx.rr.com/badour
Knowledge Base Info:
http://support.microsoft.com/default.aspx?pr=kbinfo
"Don Phillipson" <d.phillipson@ttrryytteell.com> wrote in message
news:e2NMkCAoFHA.2540@TK2MSFTNGP15.phx.gbl...
>> for Optical.
> Don Phillipson
> Carlsbad Springs
> (Ottawa, Canada)
G
Guest
Guest
Gary D. <ignore@notvalid.net> wrote in
news:bvnrf1hpclti01qaq90qdicg8f8prcs0d4@4ax.com:
> 1st HDD (C:)
> 2nd HDD (D:)
> Floppy (A:)
> CD-ROM (E:)
> for Optical.
Try 'Letter Assigner'
<http://www.v72735.f2s.com/LetAssig>
G
Guest
Guest
If I recall correctly, doesn't Letter Assigner run in the background? If
so, is it worth another program eating up resources just to change one drive
letter? A rhetorical question for OP, no response required. :)
Regards
"Ingeborg" <a@b.invalid> wrote in message
news:Xns96B198A59F673abinvalid@213.132.189.33...
>> 1st HDD (C:)
>> 2nd HDD (D:)
>> Floppy (A:)
>> CD-ROM (E:)
>> for Optical.
G
Guest
Guest
No, does its thing via ini via autoexec.bat at boot time; eg...
@C:\PROGRA~1\_MYPRO~1\SYSTEM\LETTER~1\LETASSIG.EXE @LETTERS.INI
/O:DRIVEMAP.DAT /CD
> If so, is it worth another program eating up resources just to change
> one drive letter? A rhetorical question for OP, no response
> required. :)
You got one anyway :)
dadiOH
____________________________
dadiOH's dandies v3.06...
....a help file of info about MP3s, recording from
LP/cassette and tips & tricks on this and that.
Get it at http://mysite.verizon.net/xico
G
Guest
Guest
On Sat, 13 Aug 2005 08:49:35 -0500, "Ron Badour" <Sorry@NoAddress.com> wrote:
Ron, it is not a rhetorical question. :)
It does not run in the background -- it runs while booting, and then quits.
It runs also when you launch it to reassign the letters.
When many years ago I installed this program, tried it an was amazed -- I
supposed then HOW it works, and asked Vadim by email, am I correct. And got
the positive in general answer.
The background of my assumption was that even C letter for the first drive is
not from God. ;)
BTW, if I recall correct -- Partition Magic can do that as well. But this
option was introduced later; besides that PM, is not my choice.
Mikhail Zhilin
MS MVP (Windows - Shell/User)
http://www.aha.ru/~mwz
Sorry, no technical support by e-mail.
Please reply to the newsgroups only.
G
Guest
Guest
Thanks Mikhail and DadiIO for the correction. Obviously an advanced case of
CRS has set in. :)
Regards
"Mikhail Zhilin" <mwz@x.REMOVEx.aha.ru> wrote in message
news:hl2sf1p1h0v048ca9sepne8ovvlf46vuro@4ax.com...
>>drive
> quits.
> got
> is
> not from God. ;)
> Mikhail Zhilin
