Changing GPU, what the difference between DDU and AMD Clean Uninstall Utility
veNtzo
Commendable
Mar 7, 2016
7
So I am going to change my AMD card to a NVIDIA card in a couple of days and Im just wondering whats the best way to get rid of the GPU drivers.. First I was thinking that I was needed to reinstall windows but after reading around on forums I now know that its not needed.. But now my new question is how I should remove the AMD drivers before switching cards.. Im between uninstalling in windows, DDU and the AMD Clean Uninstall Utility.. Another or the first question I have is actually whats the difference between DDU and the AMD utility?
I would also like if someone could give me a list of the process of switching gpu since I have never done it before :)
Sorry for my english, there might be some weird sentences in here..
When you get the card, it should have instructions on what to do during the swap. Basically, uninstall old drivers, either of the utilities are fine to use, remove the old card, plug in the new card, turn on system, install new drivers.
