Changing graphics card with my set up, need help pls.
Butters1215
Hi i have a Lenovo IdeaCentre K450.
CPU:Intel Core i7-4770 CPU @ 3.40GHz
RAM: 16GB
Motherboard: LENOVO 31900058 STD
GPU: S24D391 on NVIDIA GeForce GTX 650
I want to change to an Asus Dual GeForce GTX 1060 OC 6gb.
Do i need something? Will it fit my Motherboard?
Thanks.
you need a decent 450w or better power supply with the proper pcie cables the card requires
fit comes down to the pc case not the motherboard, as pcie slots are universal
you need to open the case and measure the max gpu length it can fit
