changing liquid cooling tubes/hose
John Sebastian
167
helo,i want to ask if it is possible to change the liquid cooling tubes/hose with a white color hose?i want to do this on my cm seidon 120m,
anybody knows????
They are all moddable if you really want them to be, I just wouldn't recommend it. It's very challenging, and you'd be better off building your own loop from scratch.
if i add a reservoir is it ok?any improvements on temp?for me its ok to void my warrnty
Dear John Sebastian,
I would not recommend removing the tubes on your Seidon 120m. This cooler is a sealed unit and it is not meant to be modified. As mentioned above removing the tubes or modifying the Seidon 120m will void the warranty.
I would suggest looking at our Eisberg or Glacer liquid coolers if you would like a liquid cooler that can be modified and expanded.
Please let me know if you have any more questions
