Changing monitor connection
Autocon487
179
So I explained about my problem about my gpu not working properly (fps lower then usual). It was answered by somebody saying I need to get a HDMI cable instead the cable I already have (VGA with a dvi plug for my gpu)
Someone mind explaining the difference between the cables.
GPU: ASUS Geforce gtx 780 direct CU II OC
Monitor: HP Pavilion 22cwa 21.5-inch IPS LED Backlit Monitor https://www.amazon.com/dp/B015WCV70W/ref=cm_sw_r_em_apa_VlVIzbTXMPHGW
VGA is analogic and don't support audio transfer
HDMI is fully digital and can carry sound and video in the same cable
http://www.differencebetween.com/difference-between-vga-and-vs-hdmi/
He probably meant you have to plug the cable going out from your monitor into the GPU output and not on the mobo's output.
Its kind of hard to explain. I explained that my new go u is giving me low fps. However someone told me its my monitor and its cable and for MD to get a HDMI cable
