Changing motherboard help!
Granit97
I just bought the motherboard asus m5a78l-m usb3.0 and km trying to put it on my hp pavilion p6733w but the cable to connect HP p/n:502216-001 9pins is all the way in the other side and my cable wont reach other there.. I need help please
If you can't read the manual that came with the board, then what on earth are you attempting this for? It's apparently beyond your skill level - take it to a professional.
As a side note, there is a very good chance, if you are using the original HD & OS, it is not going to work, OEM versions of windows are tied to the original motherboard & will generally not properly activate on a new mobo.
