Changing my power supplier
Oct 6, 2018
Hi everyone!
I think my power supplier just died, and I'm trying to find a solution.
This is my configuration:
- RAM DDR3 CORSAIR VENGEANCE CMZ8GX3M2A1600C9 1600MHZ 8GB (2X4GB) CL9
- SCHEDA MADRE ASROCK FATAL1TY H97
- VGA SAPPHIRE AMD DUAL-X R9 280 CORE 850MHZ/940MHZ MEMORY GDDR5 5000MHZ 3GB DVI HDMI DP
- CPU INTEL CORE I5-4690 SOCKET 1150 3,5GHZ 6MB 22NM HD GRAPHICS 4600 BOXED
- CASE MIDI TOWER CORSAIR CARBIDE SPEC-03 WINDOWED FAN LED ARANCIONE USB3 NERO ATX
The power supplier is the following:
- ALIMENTATORE PC XFX PRO SERIES 650W CORE EDITION BRONZE 80PLUS PRO650W
Considering a future upgrade to a 1060 for the VGA, can someone suggest me a good power supplier? No specific budget.
Thanks!
Oct 6, 2018
Thanks for the answer!
Since I'm willing to buy it now instead of ordering on a website, and the city I'm currently living in is not that big, I was considering a Corsair ATX 650W modular, which comes for 85 euros. Do you think will fit as well??
I'm not expert in electricity stuff, and I saw that some of your suggestion are 5xx W and others are 6xx W, so I think that if I stick to my previous one W (650) I should be ok also with this one... Am I right??
