[SOLVED] Changing primary display, Radeon settings
richardunn50
28
4
10,535
How do I change the primary display. I have two screen connected to a RX 550. One is connected to the HDMI, and the other is connected through DisplayPort with a hdmi converter. There is no option in Radeon settings to change the primary display. Even if I switch the cables around, my desktop is always put on the screen I don want it on.
1. Right-click anywhere on the desktop, and then click Display settings (Windows 10) or Screen Resolution (Windows 8).
2.Make sure the correct number of monitors displays. ...
3.Scroll down to Multiple displays, if necessary, click the drop-down menu, and then select a display option.
