So, I have my SSD boot disk, and 2 1TB drives that I use. I have them partitioned off into games, and then my other media. I want to have my games partition that's taking up all of one drive be spanned across maybe half my second disk, but in doing so, I would be pretty much only using that second disk, which is newer and I want to save writes on. I there a way that I can change the "order" of these disks in the spanned volume so say when I run a defrag I only write the entire disk once with games I'm keeping for a while and use the older one as the disk that gets written to with new programs?
Wow that sounded confusing.
UPDATE: I drew a diagram to help explain my point.
The grey is filled space, and the purple is free space. As you can see, I have a drive that is dedicated to games, and about 3/4ths full, that spans to my second drive which is half games and half other media. I have certain games I'll never delete that I would like to be written to once on the second drive, making that drive "first" in the volume span, so the "half games drive" will be filled up and the games drive will be 1/4 full, with all games installed after being written there. This keeps my POH lower, and helps with read and write speeds. Is there a way to change the order so when I defrag all data will fill the "half games drive" before filling the 1 tb drive?
