Question Changing system with same hdd
JackFive
147
9
585
Okay so i'm changing my system now.
but i want to know if i can use the same os installed on my current hdd or do i have to reinstall it again to use it in the new system?
plus i've 2 hdds so they wont be formatted when using in the new system right?
i just wanna know that.
Thankyou
USAFRet
129,403
5,222
165,040
20,028
Thankyou
This GREATLY depends on the difference between old and new.
The closer together the parts are, the more likely it is to 'just work'.
3 possibilities:
  1. It boots up just fine
  2. It fails completely
  3. It boots up, but you're chasing issues for weeks/months.
A clean OS install is strongly recommended, often required.
And also, the Win 10 license.
For the OS activation, read and do this before you change any parts:
https://support.microsoft.com/en-us/help/20530/windows-10-reactivating-after-hardware-change
Reactions: JackFive
JackFive
147
9
585
3 possibilities:
Thank you for your reply.
I'm currently running a dell optiplex 755 mt q6600.
and will upgrade to a sandy bridge i5 (or something else better) probably.
USAFRet
129,403
5,222
165,040
20,028
Absolutely a clean install in the new hardware.
Reactions: JackFive
JackFive
147
9
585
Okay thanks bro
But what if i don't reinstall it again ?
Sep 12, 2020
91
4
45
Windows will likely revoke your license because of a big hardware change.
Also, consider getting an SSD for faster boot times.
They don't cost that much.
A 2.5" SATA III one will be fine.
USAFRet
129,403
5,222
165,040
20,028
