Boost performance, yes, the heat will be generated not on the charging IC. The CPU, GPU are the ones heating (and yes, more performance, more power intake & charging IC could get hot) . May I ask you how do you know if its the charging IC exactly that is heating up?dude it a tool that boost performance but a lot of heat will be generated so i took the risk my lapteop heated up and the ic is fried and it is sitll heating up even after i delete the softwate i did a software reset too
with keep files
i asked the guy who recommended me that software he said that my motherboard took the high temparature as default so the ic got fried.Boost performance, yes, the heat will be generated not on the charging IC. The CPU, GPU are the ones heating (and yes, more performance, more power intake & charging IC could get hot) . May I ask you how do you know if its the charging IC exactly that is heating up?
