Charging problem laptop
norristhompson34
I broke my charging port internally in my laptop. Its is loosing there. Is there a way to fix this? Is ther an alternate way to charge the laptop?
You have to have a working port to charge it.
You need to see, inside, if it is reattachable, or if you need to get and install a new one. Should you not wish to do the work yourself, then contact a local tech. Now if it is still under warranty, you may want to contact the manufacturer and see if that repair/replacement is covered.
