Charging problem Lenovo Y580
pickupmysoup
7
Hi,
Basically at some point my laptop stop charging. Previously i used my laptop as PC and battery was always removed, but about 1 month ago my laptop started cutting out power (just shutdown without any message, black screen and thats it). It happened when i was launching games, then it sometimes cut power on booting windows. So i figured that maybe something will change when i plug in battery. And it did. I dont get power cuts no more, because at those points when my laptop shutdown, now it only stop charging (going straight to battery mode), when i unplug and plug back in charger, everythings goes back normal. So the thing is: which part is faulty? Charger? And maybe someone know how to troubleshoot this kind of problem?
BTW Everything inside laptops totally clean, thermal compound is changed, drivers is up to date (i'm saying this so that no one will suggest offering these "solutions" 😀 )
Thank You
Hi, "thermal compound is changed, the drivers are up to date" only the customer service people will ask these silly questions. I will suggest replacing the DC jack first and the adapter afterwards. The problem can come from one or both components.
